Fastfish408
Active Member
original Abody 383 (oil pan to carb) w/exhaust manifolds. From a Barracuda. The car had a fire and the carb, valve covers and intake are covered in soot so I removed to have cleaned. Everything inside looked spotless. I pulled both heads and one cylinder had surface rust. I am going to take it to my machine shop to determine if it can be cleaned or if it needs bored. Standard bore, correct numbers everywhere. Someone replaced cam with a purple shaft, double roller timing chain and dual point distributor. Will sell as is or can complete and sell in any stage you need. $2500 plus machine shop fees.
