What is the code for the wide black side stripe with the engine size callout on a 1969 barracuda? They had two different stripes, a narrow double pinstripe and a wide (about 1-1/2") stripe. What is the code for each one in black?
Can't help you on codes but the two stripe packages available in 69 were:
1. Upper body stripe; which ran along the body line from front to rear on the car it starts out at about 2.5" at the front and widens to about 4.5" at the rear. This stripe came with the engine call out when you had a 340, 383 or 440 motor. There were no call outs in the stipe on \6 or 318 cars.
2. lower body stripe; this was approximately a 6" wide stripe that ran completely around the car at the rocker panel level and had engine size decals that mounted mid fender in front of the door. It was accompanied by (2) 8" wide stirpes on the hood with small scoops.
You can get either stripe kit from Pheonix Graphics or Performance Car Graphics. I got the upper body stripe for my Barracuda from Performance and had them modify the engine call out to say 360.
