As noted above by @Rick@Laysonsis it safe to burn 93 octane or should we burn only 91 without ethanol
Thank you so much!!Fuel tank holds 19 gallons.
91 or 93 octane depends on what cam you have, and what your timing and compression is. Too many variables to give an accurate answer.....
I'd run whatever your engine likes the most.....
Thank you!As noted above by @Rick@Laysons
The octane level will depend on what your car likes.
As for ethanol free... I highly recommend it if you can get it and afford it.
The Maverick gas stations near me carry it and the price is not significantly higher.
There are some stations that have higher octane
https://www.pure-gas.org/WI
