1969 dart vinyl roof
44o gts dart
iowa
Hey guys, Tia , I am ready to order and install vinyl roof,, but not sure on what width is factory? I am getting 2?choices - a 38 seem to seem , and a 43 inch seem to seem,, it’s a gts … any help will be appreciated
Also needing one headliner rod retainer clip.. I will show a pic example Tia
Can't Imagine there would be two choices but possibly the 4 door and sedan might share one size and all the all the hardtops the other size ?
I have an original 69 swinger with a factory vinyl roof I could get a measurement in the next day or so. Might also have a clip for ya. Let me know.
Are you asking about a Vinyl roof top or the interior headliner? The image is of a headliner.
I believe he needs both vinyl roof and headliner. Apparently there are two different vinyl roof to choose from ??? Also he's looking for one roof bow retainer for the headliner
Yes, I am looking for 1 interior headliner bow retainer.
But on the vinyl roof, there are 2 measurements from the vinyl seems that run down the sides, they are saying 38 and 43 inch ,, 2 different ones?? I am lost ????
Okay maybe this might clear up the confusion. The vinyl roof encircles the rear window. By this I mean it not only covers the roof and sail panel it extends onto the Dutchman panel. The two seams on the roof are one measurement and the two seams on the Dutchman panel are the other. Might sound confusing but I will try and post pictures possibly tomorrow. If not Sunday
Oh duhhh,, so 38 inch seem on the top part and 43 in seem measurement on the Dutchman panel ???
Yes . It could be the other way around but I'm guessing it's more likely like you said. Definitely different seams. They don't continue in a straight line. Hope this was helpful. Can still check for you if needed.
Good luck
Good luck
Exactly,,, thanks
I guess the best way to describe it is that the vinyl roof is actually made up of 4 individual pieces all stitched together creating the four seams with two separate measurements
