carguy47
Mid 70s running 440 engine, rebuilt 727 transmission and new torque converter
Stock 7.25 rear, steel and aluminum wheels w/ tires
Aluminum intake, Edelbrock carb, fenderwell headers
NEW carpet, NEW dash pad, NEW power cable, NEW electronics, NEW 3-point seat belt, NEW glove box
NEW front marker lens, NEW headlight bulbs
NEW aftermarket gauges, NEW electric fan & relay
NEW Pro Matic ratchet shifter, NEW fuel line
Aluminum fuel cell and battery trunk mount box
Roll bar and sub-frame connectors
Competition Engineering front and rear shocks
Hemi hood fiberglass scoop
Lights work
Rear aluminum slots, 15x8, 5 on 4
Superstock seat and brackets
8.75 housing, 5 on 4 bolt pattern axles, third member (non-posi), and shock plates.
(missing are the U-bolts and drum brake setup)
Super Stock springs
Frame-spring relocate kit
NEW balanced driveshaft with NEW U-joints for the 8.75
NEW after-market wiring harness
I also have a complete set of 1969 GT bucket seats with headrests and tracks
(need foam and covers)
Distributor and wires are in the trunk
Clean and clear AZ title
$16,000
Lights work
Super Stock springs
$16,000
