[FOR SALE] 1969 DODGE DART CUSTOM
carguy47
Phoenix, Arizona
Mid 70s running 440 engine, rebuilt 727 transmission and new torque converter
Stock 7.25 rear, steel and aluminum wheels w/ tires
Aluminum intake, Edelbrock carb, fenderwell headers
NEW carpet, NEW dash pad, NEW power cable, NEW electronics, NEW 3-point seat belt, NEW glove box
NEW front marker lens, NEW headlight bulbs, NEW aftermarket gauges, NEW electric fan & relay
NEW Pro Matic ratchet shifter, NEW fuel line
Aluminum fuel cell and battery trunk mount box
Roll bar and subframe connectors
Competition Engineering front and rear shocks
Hemi hood fiberglass scoop
Lights work
Superstock seat and brackets
Clean and clear AZ title
$12,500
I can add ($2500) the following:
· Complete SBP 8.75 rear with third member (non-posi), disc brakes and shock plates
· Super Stock springs
· Frame-spring relocate kit
· NEW balanced driveshaft with NEW U-joints
· NEW wiring harness
No, you didn't miss it.
Yes, project car. that still need some work.
IF I end up selling the parts with the car, I have a NEW balanced drive shaft as mentioned. It will fit the 727 to 7290 yoke.
As is, the drive shaft will not connect to the 7.25 rear and is not included. One would have to be made.
Having said that, I may have an original one that could be shortened.
I should also mention (now that I am looking at the pictures) the distributor and wires are in the trunk. I will be doing some more work on it after the new year.
