RSP69
Member
Hello, I'm selling my 1969 Dodge dart that went through a complete restoration starting in 2004 and completed in 2011. the car was taken down to the bare body tub and then media blasted inside and out revealing no prior body damage on this very straight CA. car. it then received a high end paint job. all panels are original to the car. following is a list of upgrades performed. balanced and blueprinted 1971 340 X heads standard bore with mild street cam.
built 727 trans with shift kit/B and M stall converter.
TTI coated headers and exhaust 3" front to back.
Built 389 case 8 3/4 sure grip with 3.91 gears.
MOPAR SS heavy duty leaf springs-new heavy duty torsion bars
Entire suspension rebuilt /entire brake system new with front disc. large bolt pattern
all new Legendary factory interior top to bottom. new weatherstrip through out.
entire car sound and heat insulated. the car has less than 500 miles on it since completion. this is an original A/C car (has not been reinstalled at this time). body fit and all body gaps are excellent. Asking $26,500.
