68GTconvert
Thinking of selling my GTS. I really don't have time to deal with it right now with a 1 year old and a 5 year old. It is pretty close to being done after a paint job. I am offering it here, the price is what it is. Thanks
http://sfbay.craigslist.org/nby/cto/5071083353.html
1969 Dodge Dart GTS - 340 V8 - 4 Speed
W1 White Stripe Delete, Power Brakes, Power Steering, AM/FM non console. Car. Very Rare!!! ONE of ? Ha I don't know but it is rare. White with Black Interior black vinyl top GTS. Car is in the GTS registry. Matching numbers besides the 4 speed trans which is a correct year. I bought this car from a friend it was his high school car. He had it stored for 20 years in his dry garage. I bought it and it has been stored in my garage since about 4 years ago. It did sit outside for a bit when I moved to my new house but it was covered and tarped. I started to restore this car and it is rust free. I came to a stand still. It needs paint and to be put back together. I have everything bagged and labeled. It has the matching numbers motor which turns over freely. Fender tag is there but no build sheet.
So much to say. I rebuilt the whole front and rear suspension all new PST bushings . Front has Tubular UCA's and adjustable strut rods. 1.04 Torsion bars. Front K member and LCA's have been welded through all seems with LCA's boxed in with the plates. SSBC Force 10.5" Front Disks. Front and rear new KYB shocks. Front needs to be finished. Strut rods installed and steering hooked up. Rear is Hotchkis Leafs all new bushings. Brakes are all good and freshly painted. Original matching 8 3/4 with 3:23 sure grip. 340 is 30 over(not sure b/c I didn't take the heads off) and has stock parts beside whats listed below.
Body is very straight and rust free. It did have a minor accident but it is straight. Body work was started years ago but looks pretty decent. Everything has no rust. I went through took everything out and scraped minor scale off the floors and trunk and rust encapsulated the whole interior. There were no holes throughout the pans. Has a hole cut in the radiator support for who knows what but I have a replacement piece for it. Vinyl top was replaced and there is no rust under it should clean up with some amorall. I reundercoated the whole bottom of the car. You will not find a real GTS this clean. It doesn't happen. I tried to get this car for 7 years.
I took the dash part and painted it. It looks nice with a small crack on the passenger side.
New rims SBP and new tires. 215/45/17 front and 235/45/17's rear. You could go bigger in the rear.
It will come with almost all parts to reassemble bumpers linkage etc. Brand new dash trim($500), Nice Seats. Seat belts. New summit exhaust with brand new knock off flow masters mufflers. Hood inserts, hood trim. New carpet for a 4 speed car. Clean title. Rear GTS Panel. Grill with brand new bezels. Taillights with decent bezels.
The car is missing the exhaust manifolds, radiator, the original carb, steering box, master cylinder, AM/FM(but comes with nice AM) and air cleaner. It was set up for a more handling car. This car is ready to have some body work, painted and put back together. I tested all the lights etc and they all worked before I took it apart. I am sure I am missing something or a lot. Ask any ?'s you want. I have a 150 pictures with a link, just ask. I have done tons of work to this car. But it still needs love. Will need to be towed.
Fender Tag Decode:
LS23:
Dodge Dart,Demon
Special
2 Door Hardtop
P9B: 340 275HP 1-4BBL 8 CYL
1969
Dodge Main, Hamtramck, MI, USA
355936: Sequence number
E55: 340 cid 4 barrel V8 275hp
D21: 4 Speed Manual Transmission
W1: White Exterior Color
P6X: Trim - Premium, Vinyl Bucket Seats, Black
X9: Black Int. Door Frames
422: Build Date: April 22
354108: Order number
C55: Bucket Seats
G11: Tinted Glass (all)
M21: Roof drip rail moldings
M25: Wide sill moldings
R21: AM/FM Radio (5 1/2 Watts)
V1X: Full Vinyl Top, Black
V88: Tranverse Stripes, Deleted
END: End of Sales Codes
GTS Registry:
LS23P9B355***: GTS#469: Rob K. from San Francisco has been watching and waiting for this 1969 GTS for the past 20 years. It belonged to his friend, and has not been started for the last 16 years. Rob finally convinced his buddy to let this 340 4 speed GTS switch owners and land in Rob's garage. This is an all original GTS that is in the process of having the paint and body work completed. It was equipped with the W1 White paint job with a black interior and black vinyl top, however, it is a V88 Stripe delete car.
$12,000
This is a rare car. So I don't mind keeping it.
Fender Tag Decode:
LS23:
Dodge Dart,Demon
Special
2 Door Hardtop
1969
C55: Bucket Seats
GTS Registry:
$12,000
