Competition
Posting up a feeler add for my driveline in my 1969 Formula S barracuda. The engine is still in the car, so it can be heard running, and driving. It is the original numbers matching 340 small block, the bottom end is stock other than a set of forged pistons. It has the iron X heads on it, a small purple camshaft, Edelbrock RPM Air Gap intake, double roller timing chain, high volume oil pump, Milodon Oil Pan, Holley 650cfm street avenger vac secondary carb, Mopar wrinkle black valve covers, MSD pro billet dist, MSD plug wires, and some other stuff I'm sure I'm forgeting. The trans is a 727 built up with upgraded clutches, sprag, manual reverse shift pattern valve body, and Derale deep pan. Converter is a 10" Fairbanks around 3000 stall. Looking to get 3500 for the engine complete carb to pan with the trans and converter. Setup is located in Toledo, OH.
