It goes in from behind the dash frame. The plastic trim goes on then the bezel. If you have the light option it gets sandwiched between the housing and plastic trim.
Here's pics. Mine wobbles a bit too. I think there is a steel shim/plate missing. It may go in the back between switch and the metal box/housing?? More digging for the plate/shim. Anyone got a pic of it??
Thanks! This explains it!
Crap! mine doesn't have the Dash frame bracket as seen in your photos 1 and 2 .on :
I'll have to make something up.
Yes that would be an issue.
It also has the locating tab for centering and holding it from turning.
Hope the dash is not re-finished yet. If so you may want to epoxy it on.
