[SOLD] 1969 Plymouth Valiant
shadow 21
greensboro, n.c.
Rating - 0%
0   0   0
1969 Plymouth Valiant, 2 door post car, 340 with a 727 automatic, 8 3/4 rear with 3.23 gears, this car is really nice and runs great. It is located in Greensboro, N.C. White with a blue interior. This car has been checked by the North Carolina DMV. $14000.00. The car has front disc brakes. I have had a few people ask if I was interested in a trade, the answer is no, the only reason for selling the car is we are planning on moving to a place that has no garage and this car is too nice to set outside. I also have the factory valve covers and air breather to go with the car.
What a beautiful car. Questions.
1. is it number matching?
2. if not, what year 340?
3. does the 8 3/4 have a suregrip?
4. do all the gauges work?
1 is it number matching? No
2 if not what year 340? was told it was a 1970
3 does 8 3/4 have a suregrip? yes with upgraded axles
4 do all gauges work? No, the amp gauge has been bypassed, the fuel gauge works but not real accurate, the temp and oil pressure gauges have been disconnected with after market gauges mounted under the dash, it also has a volt meter under the dash.
A little more information about the Valiant
1: 1970 340 rebuilt with less than 6000 miles, mopar performance 484 cam, port and polished "J" heads, electronic ignition, hd oil pump, hd water pump, mini starter, stock manifolds, edlebrock manifold, aluminum radiator.
2: Rebuilt 727 with 2400 stall converter.
3: 8 3/4 rear with sure grip and 3.23 gears.
4: 1973 Duster front end with disc brakes, front end rebuilt with PSI kit.
5: Big bolt pattern 15" police rally wheels with 215/70/15 front and 235/70/15 rear tires.
6: 143,000 original miles, I am the 5th owner
