1970 383 block, cleaned, checked, bead blasted, bored .030", new cam bearings and plugs. Forged crank, cut .010"/.010", new main and rod bearings, connecting rods, cast pistons and rings. I don't know if you want to use these pistons, they sit pretty far down in the hole (.080"ish). Block numbers are 2468130-9. $850.00 o.b.o., pick up or I could possibly meet you somewhere. Located 30 miles north of Pittsburgh Pa
