mischiefdart
This 1970 Dart project is a roller. Was originally /6 automatic. I bought the car pretty much as is. The car is mini tubbed and has sub frame connectors welded in. Has a narrowed Dana 60 housing with early big ford ends and bearings. The axles are the old 7 1/4 ones sleeved to a light press fit so the car is movable. No rear brakes or guts for the Dana. Has front bbp disc brakes. Inner fenders are not cut for fender well exhaust. Hood is drilled for a dual snorkel hood and an original scoop comes with car. No broken studs but outside of fiberglass will need some work. It comes with a 1966 std. bore 440 block and a big block 727 core. Trans is probably from the seventies but not sure. Windshield is broken and interior needs a lot of help. Needs typical rust repair but not in bad shape. PA title in my name. The car is In Chichester. Asking $ 3,400 as is where is.
