BarelyaV-8
1970 dodge dart swinger 2 door
Blake
This car is only for sale because I have a child due in 7 weeks. I have completely rebuilt the motor and front end of this car over the past 5 months. I do have before, during and after pictures and over 7,500.00 in receipts.
Body - 52,934 original miles
Chrysler B-5 Blue with Vinyl white top
Spoiler, hood scoops, and stripe
Body is clean with no rust
Engine - 318 rebuilt from oil pan to carburetor over past 5 months
Block, heads and valves all done at Hi-tech Motorsports out of Elk River MN.
New items
- oil pan
- comp cam I have cam card still
- aluminum fabricated valve covers (K&N breathers)
- water pump
- fuel pump (Holley)
- carburetor (Edelbrock 600 cfm)
- intake manifold (edelbrock performer series)
- flow tech headers long tube to flow master mufflers
- braided stainless steel fuel lines and filter
- all new hoses, spark plug wires, battery tray, chrome hardware, radiator painted, four barrel carb linkage, block was prepped and painted the list goes on and on
Suspension and Brakes
Brakes - front disc brake conversion
New spindles, bearings, hub, calipers, rotors, upper control arms, lower control arms, lower and upper ball joints, idler arm, pitman arm, tie rod ends inner and outer, adjuster sleeves
All the suspension has been replaced and gone through in the front of the car nothing was left un touched.
K-member was removed sand blasted and painted.
Wheels and tires
New 15x6 in front with Goodyear tires 205/65/15
New 15x7 in rear with BF Goodrich Radial T/A 255/60/15
Interior
New headliner, carpet, seats recovered and dash pad
I have new window felt not installed in a box
I also have a new gas tank in a box not installed
I have the original intake manifold, valve covers, oil pan, carb and much more
14,000 obo
Blake
New items
- oil pan
- water pump
Wheels and tires
Interior
14,000 obo
