[SOLD] 1970 dodge dart drag car
440outlawdart
west county,mo.
sold as roller.1970 dodge dart,all fiberglass except roof and quarters.removeable doors.removable front end.has parachute mount on rear and cable.comes with powerglide.with one transbrake cover and one foot brake covertor 5500 stall,hipster trans brake.recent last year nhra 850 cert.arm front end,4 link rear,ford 9 inch with strange aluminum carrier .486 richmond pro gear..40 spline mw axles,5/8 studs,coil overs at all 4 corners,disc brakes all 4 corners,aluminum drive shafthurst quarter stick,electric shift.delay box.msd 7al box,msd cil,aluminum radiator with fan,trans coller,set up fpor 2 batterys but no batterys.holley pro max full pump.alston switch panel.all aluminum interior.sqare tube chassis.paint is ok from a distance.no vin,no title.bill of sale onlycar was built at chassis technolgy in ohio in 2000.which is no longer around.phenix f/s 14.5x32-15 slicks.near rear weld wheels.comes with headers set up for big block with front engine plate and
mid plate,has a rear wing.funny car cage.was raced at mo-kan in 2022.11.500.00.obo.pm me here
i curretly have a 400/512 in it i bought locallly new build and cant get to run correctly.car has becoome a money pit and must go i will pull the motor to sell as a roller.will sell engine with car for more money.spec on engine....Engine Details: - 400 Cold Weather 230 Block (.030 overbore) - This is strongest Mopar production block, very hard to come by as they only made them in the summer of 1971. - Molnar Forged Crank and Rods - Ross Pistons (10.5 to 1 Compression for pump gas) - TRICK FLOW 270 HEADS!! (very hard to find right now) flow 353 cfm on the intake at .700 inch lift. - Comp Solid Roller Cam and lifters( see picture for specs) - Smith Push Rods - Harland Sharp Roller Rocker Arm (1.5 ratio) - Indy Max Wedge Port Intake (4500 flange) - ATI Harmonic Balancer - 1020 Holley Dominiator Carb Built by Dominic at Thumper Carbs (Dominic is know for building Dominator's that run well on the street and strip) - BLP Racing Fuel Log - MSD Billet Distributor - Taylor 9MM Fire Power Spark Plug
