A340
B-7 Blue with Black Bucket Seats & Interior that has had every nut and bolt removed and reassembled. The body was stripped and repainted in 2006. In 2009 and 2010 the following was completed on the car.
INTERIOR
New Windshield gasket installed along with new weather stripping for the rear side pop-out windows. Wiper Arm gaskets and new inside Firewall Insulation. Seat tracks rebuilt, New 80/20 carpeting, New Rear Package Shelf w/speaker holes, New headlight switch, Steering Column and Wheel rebuilt, Dash Gauges and lights all updated and rechromed. New Heater Core along with new hoses. All other weather stripping and gaskets replaced around doors, windows, Tail lights, Trunk, etc.
SUSPENSION
New wheel bearings, brake pads, rebuilt calipers, refinished rotors, new brake hoses(3), and new steel brake lines. New sway bar link pins and bushings, New Ball Joints, Tie Rod Ends & Torsion Bar Bushings. K-Frame was removed and sandblasted. Rebuilt Steering Gear Box. New U-Joints, New XHD Mopar leaf springs, shackles, bushings and U-bolts. New Master Cylinder, New rear brake pads, wheel cylinders ,hardware, cables, etc. New brake drum, new BF Goodrich tires, trim rings, and lugs. New Gas Shocks all the way around, Wheels are painted the correct argent silver color. New Gas Tank and sending unit was also installed.
COMPLETELY REBUILT & BALANCED IN 2010: LESS THAN 1000 MILES:
Bored .020 over: New Pistons, Rings, Bearings, etc. Hardened Valve seats: Milled heads, Everything new! Including New Clutch & Pressure Plate & Exhaust System.
$25,000 obo Located in Baltimore OH
1970 DUSTER 340 4-SPEED
MATCHING NUMBERS-RESTORED TO ORIGINAL STOCK CONDITION-FENDER TAG & FACTORY BUILD SHEET INCLUDED
INTERIOR
SUSPENSION
ENGINE
