David D Schnelker
Active Member
Anyone know how to disconnect the master cylinder from the brake pedal linkage on a 1970 Duster. I pulled the 4 nuts off of the fire wall - but the linkage won't let loose of it. Even after I pulled the 2 bolts in the back of the master cylinder and spun it a full 360 degrees. It won't come off. It's a manual front and rear drum brake system w/ 9/16" nuts on the brake lines. I added a couple of pics in case it might help identify what type it is. thanks
