the Hunky
Active Member
1970 Plymouth Duster Show and Go!
Runs on pump gas! Complete sand blasting & sealer replacement . Rotisserie restoration. 4 point roll bar. Custom dash board. Stewart Warner gauges. Has tach & shift light. Custom seats & belts. Insulated fire wall & floors. All new interior headliner, weather striping, front & rear glass weather striping, front door panels carpet & custom floor mats. Rebuilt heater plenum assembly & new heater core. New wiper pivot seals. Modified heater blower to clear R/valve cover. Tubeular front Kframe. Complete Hemi Denny front end conversion to coil over springs. Fiberglass hood with six pack scoop. Fiberglass front & rear bumpers. 15 gallon fuel tank in trunk. New red top 800 CCA Optima battery in trunk. Centerline forged wheels. 12 inch C body drilled & slotted front brake rotors with Wilwood calipers. Silicone brake fluid. Engine Chrysler 440 bored & stroked to 497 cubic inch. Forged pistons, crankshaft, & rods. Indy EZ heads & intake manifold. Lunati solid lifter roller cam. Comp cams steel roller rockers . Full pressure rocker arm oiling. Biggs stage7 950cfm carb. TTI 2 inch headers & TTI X pipe complete exhaust. Innovate fast acting O2 sensor with recorder. MSD Distributor. Transmission all racing clutches. Summit deep pan. Manual reverse pattern valve body. TCI super street fighter convertor. Floor shift. Drive shaft safety loop. Front & rear subframes tied. Braced rear axle housing. New clutch type Doctor Diff posi with new 4.10 Ring & Pinion. High strength axles. Caltrac springs & traction bars. Color 2007 Charger Green.Rotisserie Restored. If interested I have over 20 pics on haggle me.com . with full description of all mods. Over 80,000 invested. 43000.00
