1970 duster project orange duster(unrulyproduster)
unrulyprocuda
unrulyprocuda
Evansville indiana
will be one of the the coolest Dusters on the planet
1970 plymouth duster pro touring car
$70,000.00 invested already started with a rust free 1970 duster professionally customized painted and ready to assemble
The color is house of color tangelo pearl orange
tons of parts go with this car and lots of custom made features on this car finished there will be no other duster to rival this car my plan was to build a pro touring car with big wheels and big brakes tangelo pearl orange with baseball glove tan leather interior there is 22,000.00 dollars worth of chrome from advanced plating in tennessee if it could be detaced and made of steel the previous owner plated it
Here is the break down of parts and features
Body 1970 plymouth duster
the car is in excellent condition no rust at all painted house of color tangelo pearl orange
and ready to be assembled flawless paint and body work over 20,000.00 invested
set up for automatic
professionally done 8 point cage with drop out bars that are chrome plated
custom made fiberglass 6" cowl in duction hood
mini tubbed with inset spring relocation kit
smoothed firewall,radiator support and all seams
shaved door handles and marker lights
built in parachute in tail panel trunk latch moved over 3"
cut out for fuel cell in trunk
dash molded into roll cage
Drive train
1969 340 forged crank ,balanced and blueprinted by kammer&kammer of ohio w build sheet
mechanical cam with adjustible rocker arms 1.6 ratio
polished eldelbrock heads ported and polished & port matched to intake
chrome edelbrock 6 pack intake with tall adaptors and willys six pack carb set up
custom made chrome six pack intake air cleaner (awesome) one of a kind
chrome hamburger oil pan with pick up
polished fabricated aluminum valve covers
motor is un assembled except short block
factory timing chain cover
chrome custom made hedman headers with collectors
fluid dampner
new arp head bolts
mopar performance lifters
complete gasket set
rocker shafts & shims
distibutor drive
Crome accessories
22,000.00 in chrome all done by advanced plating in tennessee the best in the world
previous owner went over board here is the list
chrome complete rear end housing 8 3/4
chrome rear end center section 489 case with 4.10 gear
chrome super stock springs
chrome housing floaters for rear end
chrome all hinges for trunk and hood including springs
chrome lower control arms
chrome tubular upper control arms
chrome strut rods
chrome rear and front shocks
chrome ladder bars for rear set up
chrome front disc brake spindles
chrome front brake calipers
chrome front brake backing plates
chrome torsion bars
chrome transmission mount
chrome magnum hp timing cover and accessories
chrome heddman headers & collectors
chrome turn down exhaust tips
chrome aero chamber mufflers
chrome spindle mount motor mounts
chrome windshield wipers
chrome crank pulley
chrome radiator hood latch support front
chrome hood latch
chrome trunk latch
chrome mini starter
chrome manual fast ratio steering box
chrome drag link all steering link including pittman arm sleeves
chrome lower control arms adjustment bolts
chrome 100s of bolts nuts and washers all the hard ware needed to bolt everything together
chrome six pack air cleaner hand made one of a kind
chrome six pack intake and adaptors
chrome door sill plates
chrome trim most all has been chromed
chrome valve cover breathers
chrome rear view mirror
chrome spring shackle kit
chrome oil filter
chrome braided dipstick
chrome braided brake lines
chrome throttle cable
Parts I have
excellent condition shark tooth grill and headlight bezels
new custom built aluminum radiator polished with front screen
new spal electric fan
new tci 904 small block 2500 stahl converter
904 transmission
new custom made flush tail light lenses and led tail lights
new flatlander parashute
new metro rubber door seals and trunk seal
new electronic key fob door locks and poppers
new electric trunk latch release
new black 8mm spark plug wires
front bumper chrome needs rechroming
bottom back seat gray tweed
k frame work done and painted spindle motor mounts
back glass
quarter windows
door glass
new street rod head lights
under dash hidden master cylinder and brake pedal
gas pedal
new polygraphite front end bushings
new small block fexplate&bolts
new fiberglass front chin spoiler
new moser narrowed axles
new catwhiskers for doors and windows
nissan altima bucket seats
black 20x11 boss wheels for back no tires or fronts
parts i need to finish the right way
set of wheels and tires set up for 20x12 rear and 18x8 front
rear disc brakes preferably wilwood or baer
carpet
air ride or not
door panels
wiring kit
tilt steering column and wheel
gauges
stereo system
fuel cell
battery box
upper backseat have lower
driveshaft
brake mastercylinder
billet specialties air condition pulley set
classic auto air air unit
front and rear bumpers
any questions
you can email me at unrulyprocuda@aol.com ask for Bob
extra pics available
Wow that is going to be an amazing car, a moderater should come and kick that guy outta the damn thread. He seems as though he is illiterate anyway!!
Jeff
oem pisson parts? go look in the junk yard ricer kid plenty of jap parts there
that wouldn't be a Lamborghini tri-coat color would it? white base/pearl orange/clear?? we just did a SS dart in that
the orange with the tons of chrome ought to be an eye catcher. pretty darn nice. i will be watching this one!!!!
first of all thanks guys and this aint slant eye bodies .com go home with that lame riceburnin **** if yor not into mopars you shouldnt be aloud to register on this site he should register with the sexual offender registration for getting his d$&k stuck in his nissans tail pipe
well onto better things its not a willys its a 1940 dodge business coupe straight axle gasser with soon to be 354 blown hemi
and the color is tri coat orange but its tangelo pearl orange house of color vey simular to the lambo color dart looks good
its funny because im putting nissan maxima seats in the duster he must of read that
very cool on the gasser! and that color is very close!! had to tell from the pics but must just be shades off of each other!!
I am going to have to agree very strongly. I def live very strongly to the MOPAR OR NO CAR slogan. I have never owned anything other than a Mopar and I never intend to.
Jeff
I want to dryhump your car. But, why do they call it dryhumping when I always need a towel after?
Seriously though, looks UNREAL. VERY nice job. Thanks for the look at the engine bay, gives some motivation to keep working on this one!
