1970 Duster Tube Chassis
DRGRCR74
Member
Middle Tn
Rating - 0%
0   0   0
I am selling or trading my race car. Selling as a roller as the engine spun a bearing before being put away. Specs are as follows.
Square tube chassis car.
Dana 60 rear end with 4.88 gears.
fiberglass hood, and removable lightened front clip.
all aluminum interior, including seat. removable steering wheel.
lexan windows all the way around
Will fit a larger driver, as I am 6' and 320#'s if I fit, you will
The brakes are aerospace disc all the way around, less than 100 passes, and aluminum wilewood master cylinder
Race prepped chrysler 727 with a tranzact trans-brake freshend last season.
All the transtunnel comes out for ease of working on things.
Biondo Mega 200 delay box
msd 6-al
switch panel
fuel cell is mounted up front, and has a belt driven enderle pump
aluminum radiator and electric fan.
motor, although not working, has some great parts. CSR water pump, aluminum valve covers, alcohol carb, steel heads that have been worked, square pan for a tube chassis car
new hoosier front tires last season, rear goodyears 32x14.5x15 also new last year. might have 30 passes on them
Car ran 6.50 in good air 1/8th mile. It runs straight. Body is ok. This has way more than the typical roller. With a little motor repair you could be racing. With some tlc it could be a really sharp car.
I love this car, but with a family it is hard to go race. I will sell the car, so make me an offer. Or I would trade it for a decent street car. I am not looking for a huge project, so please dont offer that, but I will consider just about anything.
If you would like to talk give me a call at 615-351-2801 Thanks for looking Josh
