moparduster777
Member
1970 Duster
EBAY LINK:http://www.ebay.com/itm/Plymouth-Du...acab74f89&item=321228590985&pt=US_Cars_Trucks
Louisville,Ky
Asking 20k O.B.O
Accept Cash!
Car Is Brand New!!
Paint is less than a month old!!
*Interior*!!
Brand new headliner
8-point cage
New dash cap
Hurst quarter stick
Original Dash with cluster and glovebox
Key buzzer works
Dome light works
All turning signals hazard lights brake lights head lights low beam and high beam all work
Has new lightweight carpet
Also have the back seat, the heater box, the controls, original seat belts, transmission/wipers/motor
*Engine*..!!--
1970 340 Block .30 over
Sony Bryant billet crank 396 stroked
Custom Manley 6.125 rods
JE piston 12 1/2-1 Dome
Lunati 645 solid Roller Cam
Comp Roller lifters
Crower Custom 3/8 Push Rods
HEADS-W-2 race heads ported by Gerald Geary Flowed .307 and some on Indy Flow bench!!!..
Valves-One piece stainless Ferrea valves
Bronze Guides
Springs-Race K-motion
Comp Double Roller timing set
Moroso oil pan and pick up SFI fly wheel
Retainers-Comp Chromalloy
Rocker Gears-W-2 flat stand 1.5 Mopar
Intake-Holley Strip Dominator ported to match heads 2in Raiser ported to match intake
Carburetor-1050 Holley Dominator
Fuel Pump-Holley 350 Dominator
Fuel Regulator-Mallory 3-way by pass
Fuel lines-All stainless with A/N fittings
Fuel Cell-Moroso 12-Gallon with sending unit
Flexplate-SFI
Electric Water Pump SFI
Electric Cooling Fan
Line Lock..
*TRANSMISSION*...!!
727 Rollerized
Red race clutches
Bolt in Sprag
Output shaft with bearings
TCI Pro Brake
8in PTC 5000 Converter
SFI Kevlar Shield
Reverse Manual Valve Body
*REAR END*..!!!
Dana 60 Car rear end
Axles-Strange 35 Spline
Strange spools
Gears-538 Pro Gears
Coil overs-Strange adjustable
6-Ft wheelie bars
Mini Tubbed
Hurst quarter shifter!
ALL NEW upper and lower ball joints
Brakes-Disc brakes on front and drums on the rear
*BODY*!!
B-5 blue paint
Hood-Fiberglass hood with 5 inch 6-pack scoop
Grill-Real Shark tooth grill Bulbs work
Front bumper-Fiberglass
Rear bumper-Steel bumper
NEW PPG windshield all other glass is original..
NOS turning signals!!
Dual batteries in trunk
New low weight master cylinder
Louisville,Ky
Asking 20k O.B.O
Accept Cash!
Car Is Brand New!!
*Interior*!!
Brand new headliner
8-point cage
New dash cap
Hurst quarter stick
Key buzzer works
Dome light works
*Engine*..!!--
Comp Roller lifters
Bronze Guides
Flexplate-SFI
Line Lock..
*TRANSMISSION*...!!
727 Rollerized
Red race clutches
Bolt in Sprag
TCI Pro Brake
SFI Kevlar Shield
*REAR END*..!!!
Strange spools
Gears-538 Pro Gears
6-Ft wheelie bars
Mini Tubbed
*BODY*!!
B-5 blue paint
