1970 Plymouth Duster Project
KOZ45
Indiana
After a long, long search......i finally have a project car to work on:
440 V8 (1968)
727 trans
8-3/4" rear
I'm in Indiana, just outside of Chicago
After popping a valve cover, I found I have the 906 heads
The previous owner installed a Weiand 7512 x-cellerator manifold, which seems to get good reviews
The rear end has the smaller 741 case with 3.23 gears, but when I bought the car I found a set of 4.30s under the seats
I have the 26" wide radiator with the 7 blade fan......might need a better radiator eventually
I need to gut the fuel system and drop the tank, remove the entire ignition system, go over the brakes, re-do the exhaust and completely overhaul the interior
A lot had been done, but alot more needs to be done
I plan on a full MSD ignition, already bought a 6AL box with NGK plugs
Also just bought a rebuilt, tuned 4150 carb
The car has nice headers, but they will be removed and ceramic coated.
Pics coming....
The huge stock starter was cooked, so I bought a $20 reman for 91-95 Dakotas
Hey! I was looking at the car on CL. I thought it would be a blast to own, and was giving it some thought..... Glad you bought it!
With it being my first project car, I was hesitant
It was a good price (n my opinion) was under 2 hours away, was pretty clean and complete.....and had an Illinois title
yeah, it was a little over 2 hrs from me. I looked at it several times in the pictures. Wondered how solid the underneath was..... It looked like a ball of fun to me
The paint job isn't good, but it will work
the car is extremely solid
All the glass is in tact also
That's an awesome score. The nice thing is having the hard work already done. After you straighten out all the things you need to, you'll have a great car to really enjoy. Again, awesome score. I like the color too.
Great car! Might want to think about new leaf springs too. Those rear shackles are LONG!!
I tore the back seat out today, hoping to find the build sheet.......no luck
Haha yes, those rear shackles are long
I like the look of of, raised up the rear for a drag car look to clear larger tires
The bolt spacing is the smaller 5x4, but it will work for my needs.......just limits wheel choices, but still plenty of options out there
When I add an electric fuel pump, what happens to the mechanical pump?
Isn't on the block near the water pump? Leave it or is there a way to delete it?
The block off plate arrived, along with a large box of goodies from MSD
Nice score.... If those are SBP slots on the back and you want to sell them send me a PM....
JW
