[FOR SALE] 1970 plymouth duster with 400 big block and dana 60 rear-end
#MadMax
Rating - 0%
0   0   0
I have a 1970 plymouth duster. The duster is a turn key car get in and go driving down the road today. This is a street car. Has title in my name. The duster has a Professionally welded in 8 point cage also can be cut outto but seats back in it. Also has frame rail connectors.
I have a set of factory bucket that need redone but will do with the car. Has all new door seals and window seals and new front windshield with new seal as well. New cat whiskers also.
The engine is a new rebuilt 400 big block pump gas engine. The block is 530 RV block all stock all new seal power bearings and rings has a edelbrock performer dual plane intake and a general kinetics 512 cam Complete MSD Ignition system. Has brand new Schumacher A body big block headers with correct Schumacher collectors.
The 727 HD with tci 2800 stall convert. B&M quick shifter.The drive shaft has drive shaft loop.
The suspension is upper QA1 control arms and drilled and sloted front disc brakes and super stock rear springs.
The rear-end dana 60 410 gear and new dura grip Yukon center section and 11" drum brakes.
All redone this pasted winter.New 15 tires and rims are mopar steely 15x5.5 all 4.
Have a video of the car running. Pm me a phone number if serious about buying and can text it to u.
Location is Collins ohio 44826
Price is $20k obo.
