[FOR SALE] 1971 Chrysler 400 Block (casting #3698630 / .030 overbore)
jjsende
Houston
Rating - 0%
0   0   0
Original machine work from Ray Barton Racing invoice dated 6/21/1999:
RBRE CORE 400 CHRYSLER CYLINDER BLOCK / .030 OVERBORE
CLEVITE B/RB/HEMI CAM BEARING SET/BABBITT
RSRE ON-TRAC BILLET STEEL MAIN CAP SET B/RB ENGINE
MOPAR PERFORMANCE SMALL PARTS KIT B/RB HEMI
MAGNAFLUX AND CLEAN
SQUARE AND CORRECT DECK SURFACES
BORE AND HONE CYLINDERS WITH DECK PLATE
INSTALL CAM BEARINGS
INSTALL BILLET STEEL MAIN CAPS ALIGN BORE AND HONE MAINS
INDEX & CORRECT LIFTER BORES w/BUSHINGS
MACHINE O-RING RECEIVER GROVES IN BLOCK
O-RING CYLINDER HEADS
Block has been kept loosely bagged on an engine stand to avoid trapping moisture, will need some clean-up to remove the white grease protectant before installing internals. Any machine shop with a hot tank can clean up the block. Block is in excellent condition, no rust or damage.
Asking $1000.00
http://www.ebay.com/itm/290943281614?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Pay Pal payment preferred, or cash at local pick up in Houston TX
WOW! That is one killer deal. I would snatch that up in a sec if i wasn't 1200 miles away.
