[SOLD] 1971 Dart Swinger - Poly Urethane Bushings - front control arms
Dave Haertel
Charleston, SC
New, still in the box, Polyurethane control arm bushings front, fits 62-76 according to Jegs.
Was going to rebuild the stock units but chose to swap out for QA1 tubular control arms which came with bushings already installed.
35 bucks plus the ride. Retails on Jegs for 46 and change.
If you want rebuild-able stock control arms, the 2 uppers are rebuild-able, and 1 of the lowers is, I'll probably add a separate ad for those but if you want them too let me know. The one lower I had to cut the connecting bolt off so I'm not sure that'd be considered rebuild-able.
Is that for all four control arms. If so I’ll buy them. Thanks. Kim
Not sure o just have the one box but I believe it is yes. I’m not home but will check when I get there. If you zoom in on the picture I think you can search the part number on kegs to see
