Looks nice . However I thought the shifter itself had Hurst stampings. I have one like yours with no stampings and assumed it was the Indy aftermarket type. Can anyone verify which is OEM? Stamped or unstamped. 66F is the reverse lever stamped with 6353? Thnx
Yes, the reverse lever is stamped 6353. Aftermarket Hurst shifters will use the larger bushed hole in the reverse lever. I would have to look closer for Hurst markings. The shifter and handle has been in a tote for probably 30-40 years.
