[SOLD] 1971 dodge dart drag/show car
Moonkryket
SE Vriginia
Rating - 0%
0   0   0
1971 DODGE DART
1971 DODGE DART 4 DOOR DRAG/SHOW CAR 3,165 LBS.
FIBERGLASS FRONT VALANCE, FRONT BUMPER, HOOD AND REAR BUMPER
YEAR ONE STAINLESS HOOD PIN SET
AC REMOVED HEATER BOX REMOVED
MANUAL STEERING FRONT DISC BRAKES WITH LINE LOCK
B BODY WHEEL BOLT PATTERN
SOLID MOTOR MOUNTS WELDED FRAME BRACES
RELOCATED (3”) NEW SUPER STOCK SPRINGS NEW 90/10 DRAG SHOCKS F&R
NEW 4.30 DETROIT LOCKER 83/4’ REAR MOSER AXLES 3” STUDS
WELD DRAG LITES 10” REAR 4” FRONTS
NEW 10”TREAD X 28” HOOZIER DOT SLICKS - NEW MICKEY THOMPSON SPORTSMAN FRONTS
NEW MALLORY 140 ELECTRIC PUMP NEW 10 GALLON TRIANGLE FUEL CELL
½” FUEL LINE WITH ½” RETURN FROM BYPASS REGULATOR
BATTERY RIGHT SIDE TRUNK WITH VENT
TURBO ACTION 904 AUTOMATIC WITH REVERSE MANUAL SHIFTER AND HIGH RATIO LOW GEAR FOR EFFECTIVE FIRST GEAR AXLE RATIO OF 4.67
DYNAMIC 3400 STALL 10” CONVERTER
TRANS COOLER WITH FAN
DUEL FRESH AIR UNDER BUMPER INTAKE TO SEALED FILTER BOX
BATTERY IN ALUMINUM ENCLOSURE IN TRUNK
ENGINE: NEWLY BUILT 1971 340 - 40 OVER ROSS SUPERLITE PISTONS
11.50 COMP. RATIO WITH STOCK 65CC ALUM. EDELBROCK HEADS
EAGLE H-BEAM RODS WRIST PINS
LINE BORED BLOCK DECKED WITH PLATE
FORGED CRANK FLUIDAMPER
BALANCED SPINNING ASSEMBLY
COMP CAMS MAGNUM 525 SOLID LIFT CAM COMP CAMS PUSH RODS
COMP CAMS DOUBLE ROLLER CHAIN AND SPROCKET
MILODEN 7 QUART DEEP PAN WITH PICKUP
NEW HOLLEY 4150 RADIUSED INLET 750 MECH. SECONDARIES CARB
NEW MOPAR M1 SINGLE PLANE INTAKE
MSD 6AL MSD 8MM WIRES MSD BILLET DISTRIBUTOR
MSD TIMING COMPUTER
CERAMIC COATED HEADDMAN 15/8” EQUAL LENGTH HEADERS
3” EXHAUST 3” BORLA STAINLESS MUFFLERS 3” PIPES TO AXLE
ENGINE HAS NEVER BEEN STARTED –EVERYTHING IN ENGINE, TRANS AND DRIVE LINE IS NEW- CAR HAS NEVER BEEN WRECKED OR RUSTED AND HAS BEEN IN FAMILY SINCE PURCHASED NEW IN 1971 – HAVE TITLE
New paint, vinyl top, door handles and rear view mirror - body is perfectly straight
To be completed by buyer: (have all parts )
Install all exterior lighting - run fuel lines from electric fuel pump to engine - install radiator/hoses - install trans oil cooler - install alternator and brackets (all chrome/new) - install inside door panels - install grille - install front and rear bumpers (pre mounted before painting) - install under the bumper electical quick shut off
1971 PLATES TO GO WITH CAR. $9,000.00 SE Virginia
My Age related physical condition is reason for selling.
PM me for details
PM sent
2nd PM sent, waiting for contact.
Thank You
Contact made with seller, we are talking tonight.
makes this car unique......built with all the good stuff like this:-) Those getting blasted by will make the pain even worse:cheers:
Several people interested:-)
Beautiful car!! I have to ask,what kind of air cleaner housing is that?
Yeah, where did that air cleaner housing come from? Doesn't look like it would clear a kickdown linkage though.
It clears everything.....Cheeta reverse manual shifter with built 904 tranny. I forgot where I got the housing but I fabricated the flexible air intakes.
