71swing
FOR SALE: A 1971 Dodge Dart Swinger. $21,000
Before I begin this is originally a slant 6 car, but has been converted to a small block car. This is no numbers matching car. No joy rides, serious buyers only. Current state of the car is not drivable for testing.
Ive owned it for nearly 10 years. Pasted down from my father. Over the years I have invested a lot of money into the car. I simple have grown tired of the project. This is a great opportunity for someone to get started with a 90% finished car. Car has gone through many changes over the years. Far too many parts to sit and list. Its a must see. A few weeks back a slight fire melted the main wiring harness in engine bay and cause to slight paint damage to two small spots on hood. So car doesnt currently start, but dont let that deter you. It is an easy fix. Car is in overall great shape. It does have paint flaws and minor rust in rear quarter panels. Easily fixable. A fuel cell install was last project still needs minor finishing details to complete.
Completely new motor assembled by Charlies Speed Machine in Blair NE. currently has about 200miles on it. I finally had enough break in time to test it out a week before the fire. The car runs great and is very fast. Before this 408 install the car had 340 on nitrous that ran mid 12s. I can tell this 408 motor has more power than that ever had.
Burgundy redish paint
340 swinger hood scoops
Complete and original interior. Excellent shape!
HID headlight conversion
408CI stroker motor. (360 bored and stroked to 408)
F.A.S.T EZ EFI kit
Custom cold air intake
Edlebrock air gap intake port matched
Edlebrock performer Aluminum heads port matched, just rebuilt by Charlie speed machine new valve, seal, and spring
Mopar cast aluminum valve covers
408 short block has forged icon -22cc dish pistons, Scat forged rods, Scat cast 4 crank.
Comp Cams 2-228-4 cam 540lift with matching springs
Kevco 5QT. deep sump pan
Mopar HV oil pump
TTI Ceramic longtube headers
Full 2.5 dynomax exhaust
High flow water pump
Custom Aluminum radiator
Single Derale electric fan
180amp single wire alternator conversion
Crane HI-6 ignition box
Mopar electronic magnetic distributor
B&M transmission cooler
727 Torqueflite transmission. Fresh rebuild
9 Dynamic 3800 stall converter
Cone Racing reverse manual valve body
B&M Quick Silver racketing shifter, new heavy duty cable just installed
Brand new inland driveshaft
8-3/4 rear (489casting)
3:73 gears
Auburn limited slip differential
Moser 30 spline axles 4.5 bolt pattern conversion
13 gal fuel cell in trunk (needs minor install finishing)
F.A.S.T complete fuel system. Inc. Fuel lines, regulator, 80lb injectors.
Summit racing Line lock
18X8 Centerline stingray 3s rims mounted with Nitto 555s on all four corners
SSBC front disc brakes 4.5 bolt pattern conversion
Hemi torsion bars
ADDCO front swaybar
Much more parts than can be listed.
I am Located in Omaha Nebraska. Guess you can contact me through a PM since we are not allowed to list emails or phone numbers in the post.
My name is Bryan M.
F.A.S.T EZ EFI kit
Mopar HV oil pump
3:73 gears
Hemi torsion bars
ADDCO front swaybar
My name is Bryan M.
