gashaller
Member
my dart is a California car all but 1100 miles were put on in cali.it has 67010 on it now. It is painted gecko green was painted 3 years ago, had a new vinyl top put on at the same time,also has twin hood scoops.The headliner and the back seat were done by the previous owner,I had the front seat redone , put in new carpet, also put in a new dash pad, brand new B&M shifter also has amp,water temp, and oil pressure gauges and a tach. the engine was completely overhauled 4 yrs. ago, i hav e put on 1100 miles, work done including new pistons, rings, valves, valve springs, thumper cam by comp cams, all new rod , main, and cam bearings. Has an aluminum highrise intake manifold , with a holley 600 cfm on it.Distributor was upgraded from points to electronic ignition,the engine is a 9 to 1 comp. ratio also up graded to an aluminum radiator with shroud and 16 inch electric cooling fan. Transmission is a 904 that was built by A&A transmission its beefed up , it has a reverse pattern, manual shift valve body, it shifts fast and hard , it has a 10 inch convertor the combo works well together.asking 16000 obo . Thanks for looking
