[SOLD] 1971 Duster 340 4 speed Sassy Grass
toddkozak
Active Member
pennsylvania
Rating - 0%
0   0   0
I bought this car as a project and selling it as a project, it still needs some work .Great solid body with alot of original (faded) paint. Numbers match 340 car but original engine out of car and apart,of course it goes with the car, now has Magnum 360 in it, rebuilt numbers match 4 speed 3.23 sure-grip car. Original FJ6, have fender tag and build sheet.I added a '73 K-member with spool mounts, disc brakes and also added new big-bolt rear axles with green bearings. Car has 15 inch wheels. New clutch, new brakes, new flex hoses, new rad shroud, new engine harness, new power steering pump and hoses, new rallye gage voltage regulator. Has new carter electric fuel pump, new Waldrons stock dual exhaust system with new extensions, etc, etc, Car runs, drives and looks decent but has a steering gear leak(gearbox needs re-sealed or rebuilt) and needs carpet installed(I have new ACC carpet).I have another set of 71 bucket seat cores and the original rear seat core I was going to re-cover in new material but could never afford it.They go with. Nice 73 buckets and rear seat in it now. It was an original base bench interior car. $13,000, which is what I have in it.
Loving it! Could you list the data tag codes please:)
