71valiant
Make fast, break, repeat.
A 1971 Plymouth Valiant with 70,500 mileson the body . 318 .30 over, balanced and blueprinted. BRAND NEW aftermarket Magnum heads with Mopar perf. high comp. head gaskets. Hughes Performance valve springs. Comp 1.6 ratio roller rockers. Comp 480 lift cam. With the 1.6 rocker arms it brings the cam up to a 512 lift. Crosswind intake powdercoated wrinkle black to match the valve covers. Holley 650 cfm 4bbl carb, MSD Pro billet distributor, MSD 6AL Ignition box, MSD wires, Hooker Pro comp headers. 904 transmission with B&M stage 2 shift kit, Mopar 5.0 Hemi kickdown lever, PTC 3200 stall converter. Dual exhaust with Flowmaster 40 Series mufflers. 7.5 Mopar rearend with 3.91 gears and Mopar suregrip. Car is B5 blue with factory rallye rims with good rubber. Also has the rare "Sharktooth" grill that came on the 340 Dusters and a dual snorkel hood scoop.
It does need some body work. The lower rear quarters need replaced and maybe a few small patch panels. The inside is in decent shape. the dash is split in the middle, that would need replaced if you plan on making a show car. Whomever had it before me replaced the front bench seat with buckets. The trunk is in excellent shape, even has the factory spare!! I replaced the gas tank and all fuel lines last winter so all that is in tip top shape. The motor has at the most 500 miles on it.I have the reciept for the engine rebuild as well. I also have a 727 transmission that goes as well.
5500.00
5500.00
