Tduff01
I have a 1972 225 /6 from my duster. Looking for a fuel line from the pump to carb, (single barrel holly). Found one on summit that says work. Just wonder if anyone has used it or knows of one that will work. Several years ago I had to replace the fuel pump I had to make a new fitting for the fuel line at the fuel pump because 1- it didnt line up with the new pump and 2- the fuel line was cut and had a rubber line spliced in. So I put a new fitting and ran a rubber line from the pump to carb. Having to change the fitting and stuff then, is what makes me wonder if this will fit. Thanks everyone.
