[SOLD] 1972 318
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
Anyone have any interest in this before I take it all apart. Any or all of it. It turns by hand. Looks unmolested except for the missing rt side valve cover and rockers. Have to put a price, so $150 for the long block, or piece it out.
Date on block is 10-4-72
I'd be interested in all the bolts, fuel pump eccentric, pick-up, oil pump drive, cam thrust plate ect. if you decide to take it apart. Labled baggies if that is doable. Basically looking for the stuff to put together an engine. I have the block, heads, intake, oil pan, crank etc. PM me if you are considering stripping it down.
Tell me if it's a good un!
Yeah, it's a good solid foundation. I know of a heavily loaded 391 stroker built from a 1973 block with main and head studs and stock caps that gets the pee water run out if it on nearly a daily basis. With 11.4:1 and Edelbrock heads... that also does some towing duty. I'd classify that as a good un!
