[WANTED] 1972 Charcoal Vac Canister.
Crossrammed340
Basin street Blue survivor
Bradford Ontario Canada
Im looking for a clean 1972 Charcoal Vacuum cannister for my Demon project. pn # 357 7584. Im pretty sure all body styles had this cannister so it could be from a B, E or C body car as well .It must have no damage at all and complete with cap. If you have one please PM me here . Thanks FABO for the free ad.
I'm not sure what you need but if are talking about the can for gas tank fumes to carb. I have one for a 73 Scamp that was set up with a 318 that I believe is in great shape. Let me know and will send some pictures.
I just went through this, I believe the '72 and '73 canister versions have a different number of hose connections (3 vs 4). I could not find a '72 version, so went with a '73 (I also found a '73 carburetor which has the proper '73 hose connection in the throttle plate). I hope this helps some.
72
I have one in a 72 Valiant. I’ll check it out tomorrow and see what the part number is and see what shape it’s in
I may know of one on a 72 Duster that isn't being used, I'll see if I can get the number tomorrow.
I think one time I found the charcoal from the canister being sucked into my carb on my '85 Caravan, so be careful when trying to recycle these older ones. That is why I splurged NOS on a '73 canister for my '72.
Pretty sure I have a nice one and bracket I'll try and get a pic posted in a little bit.
PM me your email address for pictures, I have the exact part number you need as well as the mounting bracket.
