1972 dart front wheel hubs
dieselman966
Milwaukee
Rating - 0%
0   0   0
I trashed my wheel hub while removing the studs. So I need to find a replacement for it. Parts stores don't carry them. So do I need to start going through junk yards to find one or do I have another option.
I have one still in the drum with RH threads. The drum is scored but might be turnable.
That can ship in a usps medium flat rate box. I can get pics tomorrow.
Some pictures would be great and thanks for your help. How much do you think you would want for it?
Ok, I've got two options for you:
I found a 10" hub with two RH studs. Three were broken off but I was able to press them out. If you have access to studs, that may be cheaper. That part can go in a USPS padded flat rate envelope for 5.75, so lets say $15 shipped.
I also have a whole drum with RH threads. It has surface rust and some grooves but it might turn. I have't miked it. I can ship it in a USPS medium Flat rate for 12.70 so lets say $30 shipped on that one.
I could also try to press the hub off that drum but it's extra work :)
here's pics of both:
