W Waco Demon Well-Known Member Joined May 30, 2009 Messages 268 Reaction score 11 Location Waco Tx Nov 28, 2009 #1 Can not get nut brock loose on upper control arm ball joint . Have any ideas. Waco Demon
L limelite70 Well-Known Member Joined Mar 1, 2006 Messages 1,255 Reaction score 42 Nov 28, 2009 #2 Torches Big Wrench Big Hammer
clhyer Well-Known Member Joined Feb 24, 2007 Messages 3,734 Reaction score 320 Nov 28, 2009 #3 A 4 foot cheater bar with a lifetime warranty breaker bar and socket... C
SGBARRACUDA ROY Legendary Member Joined Dec 7, 2006 Messages 22,009 Reaction score 10,666 Location PLANT CITY FL. Nov 28, 2009 #4 Heat the arm around the joint.
6pk2goDemon Mopar Mod Staff member FABO Gold Member Joined Mar 1, 2008 Messages 10,827 Reaction score 2,464 Location Arizona Nov 28, 2009 #5 Try soaking it w/ something like PB Blaster overnight, then use an impact w/ a wobble socket and rattle it loose. If you don't have an impact, use a box end wrench and a long pipe for leverage.
Steve68 Well-Known Member Joined Dec 18, 2008 Messages 267 Reaction score 4 Nov 28, 2009 #6 If all else fails use a nut splitter.
2 Darts A-body Addicted Joined Mar 28, 2008 Messages 3,428 Reaction score 277 Location Usually in a house Nov 29, 2009 #7 clhyer said: A 4 foot cheater bar with a lifetime warranty breaker bar and socket... C Click to expand... Soak the nut with Kroil first, then try this. If all else fails, use a die grinder and cut the sucker off.
W Waco Demon Well-Known Member Joined May 30, 2009 Messages 268 Reaction score 11 Location Waco Tx Nov 30, 2009 #8 Thanks for all the advice We soaked them with WD 40 over night thay came off the next morning . Waco Demon
