[SOLD] 1972 Demon with 433 Hemi
maxie
new castle Indiana
Rating - 0%
0   0   0
Dodge Demon .
The demon:
426 pre world iron block,
diamond 11 to 1 pistons,
manly rods with .990 tool steel pins,
dick landy roller rockers,
600 lift solid roller camshaft,
callies super stock cheater crank motor is actually 433 cid,
Jesse Bigsnell 1050 Dominator
Indy 426-3 Intake
727 manual reverse pattern also built by rick allison at A and A,
dana 60 with 4.10's,
frame is tied,
caltrac split monoleafs and caltracs,
4 wheel disc brakes,
wizard radiator,
complete new rebuilt front end,
new spindles and upper control arms,
cage with swing out bars, does have a rear seat we used seat saver bars, dash fully restored,
new dash pad,
Al Bevic Hemi A body conversion kit
ricaro style front bucket seats,
tti headers and 3 inch exhaust,
calvert shocks,
new headliner,
weld wheels with MT tires,
new bumpers.
Have a new VFN hinged six pack hood for the car. The hood in the picture is gone.
I have new 70/71 fenders for it because I don't care for the 72 side marker lights, I also have NOS front bumper brackets that will go with it.
Car needs the exterior painted/finished but you can drive it now and have a blast at cruise ins. Doesn't get over 165 degrees when cruising. As you can see all the parts and pieces are first class. The car has under 50 miles on it. I have just decided to go a different direction.
Price - $ 38,000 obo or partial trades of 1968 to 1971 340 A body.
I am in east central Indiana
Have a new GLASSTEK not a VFN hinged six pack hood for the car. Also have the springs for the hood hinges that go with the glass hood The hood in the picture is gone. Here is a better description of what I have that goes with it.
I also have the following that goes with the car:
New side marker lenses
new window A pillar and rear window gaskets
new stripe kit
New Holley Pro Billet fuel pump and 1/2 inch fuel line because the new 3/8's line isn't big enough
new 1/2 inch fuel sending unit
new hood springs for the Glasstek hood
new AMD 70/71 fenders for it because I don't care for the 72 side marker lights,
new air cleaner for the dominator, just haven't ordered a filter because I don't know till the hood is on it
new door hinges
new door handles
partial trades of 1968 to 1971 340 A body or 383/440 GTS
Just to let you know what I have in it
Dick Landy Roller rockers $2100
8-10-08 got a new block from Indy heads 08 mopar nats with cam bearings $2650
10-18-08 msd6al2 ignition system $201.43
11-22-08 roller cam button $39
12-24-08 aluminum water pump and housing $170
12-24-08 melling hv oil pump $53
1-12-09 magnesium hemi valve covers $400
3-5-09 comp roller lifters swap meet $230
5-16-09 comp cams from Indy roller camshaft $325
6-13-09 intermediate shaft, intake heatshield and pushrods $430
8-7-09 ati dampner and timing set $510
8-7-09 n.o.s. hemi oil pan $35
1-31-09 callies super stock crank $300
1-31-09 mopar bare iron heads $1800
12-25-09 oil slinger, rear main holder, alt bracket, windage tray, crank bolt $221.85
3-5-10 head studs spark plug tubes $320
3-6-10 manly rods with 990 pin $500
3-6-10 fuel pump push rod $12
4-24-10 rocker arm adjusters $40
5-3-10 diamonds pistons, h13 pins and rings $1029
8-14-10 carb linkage from a & a mopar nationals $200
8-14-10 everything to build heads Indy $617
8-31-10 bolt kit for motor amk $325
9/6/2010 gasket set, block hardware kit $211
Fully machined, balanced and assembled Gary Sharpe $2800
3-25-12 hemi A body K frame, motor mounts, special steering column $1200
Dodge demon money
Bought 5/20/2012 $5000
Disc brake kit $850
Transmission from A and A $3700
Gas line from fine lines $120
Gas tank and all the stuff that goes with it from Vans $303
Leaf springs, bushings, u bolts, hanger reinforcements mancini $375
Dana 60 with 4.10’s and disc brakes $1500
Shocks, battery box, master cylinder bracket. Bushings, battery switch $549
Fuel pump, trans cooler, gauges from jegs $702
Exhaust system and headers $1591
Wizard radiator $599
Wheels and tires $1550
Seats, seat belts, lug nuts, switch panel, long wheel studs $679
Tuffy wheel adapter $80
Pitman arm and idler arm $140
Roll cage $319
Dash pad $225
Package tray, seat divider, brake lines $215
Motor harness wiring harness $110
Hood bumper kit $25
Strut rods rear spring hangers $150
Gas fill tube to trunk grommet $30
Line lock $105
Wiper arm gaskets $10
Firewall insulation $30
Windshield gasket $95
pCv and breather $179
Trunk mat and spare tire divider $47
Transmission mount $80
New rear bumper brackets $89
Fan shroud $149
water pump shim, alternator $118
New bumpers and bolts $575
Shift light, rev chips, roll bar padding, wire separators $248
Rally mirrors from PG classics $342
Drive shaft and mw yoke from dynatech $615
Sill plates $80
Seat nuts $13
Turn signal switch $45
Torsion bar boots $35
Tail light gaskets $31
N.o.s. Front bumper brackets $200
Headlight wiring harness $164.25
Indy 426-3 intake $425
Jesse Biggs 1050 Dominator $1125
Fuel Log $50
Earls fittings for 1/2’ inch $125
Plus the calvert rear suspension
