[FOR SALE] 1972 Dodge D100 Pro Touring
ZDECKICH
Member
Fort Worth, TX
Rating - 0%
0   0   0
FS: 72 D100 $13,500 obo located in DFW, TX
Ok, time to sell my 72 D100. Truck is a 318/727. 318 high performance seals,rings,gaskets,speed pro 9:5:1 pistons, Melling high volume oil pump, all rings, gaskets, bearing all new. Mini starter. worked cast heads,headers. edlebrock 650 carb, MSD 6AL box, accel coil, lokar shift cable, comp cam big mother thumper Cam comp lifters comp valve springs. Flow masters dual chamber 2 1/2 pipe. sounds awesome. , new radiator big, trans cooler, new trans 727 non lock up. new kolene steels, raybestos bands, red eagle clutches, B and M race shift kit, 2800 Band M stall. new rear 3:23 gears new posi unit from dr.diff, all heavy duty yokes, Spicer U joints. New axle seals, disc brakes in the front Truck is also lowered with flip kit rear and van lca’s. Hellwig rear sway bar, Wheels are American Racing 20x9 and 20x10. New door weatherstripping, rebuilt carb, replaced the glove box lid and instrument cluster, repainted the door panels, led headlights and regular maintenance. Truck was painted about 7 years ago, has some flaws but still shows well with a great shine. No rust on the truck except a little on the inside lower tailgate. Clean title in my name.
