This is a 1972 Dodge Demon with slant 6 and automatic transmission. Runs and drives good, new tires and brakes. No power steering or power brakes. Car has original paint and rubber floor mat, did not come with carpet. The black head liner and door panels are in good shape. Someone removed the front seat (assume it had a bench seat) and put in two bucket seats It originally had the black/white herringbone interiror. The back seat needs to be recovered. Dash pad is cracked and needs replaced or a cap added. No radio. All lights, wipers, guages work.
The body is in very good condition with a small area about the size of your hand behind each rear wheel well that has rust. There is some surface rust just in front of each rear wheel well. The quarters are solid except for these spots. There is no rust around the front or rear windows or trunk drip rail. The passenger side floor pan has some surface rust and a small hole starting to appear. This needs to be repaired. The trunk and other floor pans are in great shape. Do not see any frame rust except some scattered surface rust in places. The frame is solid. The left side of the tail light panel has a crimp in it and needs to be straightened. This is the worst of any body damage. It doesn't have any major dents or caved in panels. It does have several smaller dents and scratches. There are 2 small holes at the top of the front fenders that looked like were drilled for dual antennas. $2200.00 Call Rick Jacksonville Fl 904-234-9910. Also have complete A-Body 340 set up, 72 340 engine, 904 transmission, drive shaft, 8.75 489 case 323 posi rear end, shock plates, u bolts for sale. Engine is newly rebuiilt all for $2800.00. First time I have listed and couldn't get pictures on site. My email is [email protected]
You can see pictures of car and engine if you go to Jacksonville craigslist and under cars and trucks for sell type in 1972 Dodge Demon.
