I have a 8 3/4 A-body rear end out of a 1972 340 4 speed Duster. It is a 489 Case 3.23 open rear. I've done a lot of work on it including NEW axle seals 8695s National Seals. I re packed the original taper roller type axle bearings and adjusted them . I installed NEW Raybestos wheel cylinders, NEW Brake shoes, NEW Carlson return spring kits, NEW Carlson self adjuster kits , NEW Centric Brake Drums, NEW Brake hose. I media blasted most parts and painted the rear Semi Gloss black. Includes the E-brake cables, 7260 (small) joint yoke, Pinion Snubber, U-joint straps and bolts. Available with Shock mounts and factory U-bolts for additional $100.00.
$1200.00 Prefer local pick up But I travel to Perry Ga. ( when not under Corona lock down) and can meet someone in between. Also have a good affordable method to ship terminal to terminal with YRC freight.
