Finally getting my 72 Duster with the light package back together but I have run into some odd electrical issues- tried to trace most everything out but still need some help if possible…
Any help or chastisement is welcome!
- No turn signal lights on cluster (but fender mounted lights and front/rear lights working. (Bulbs were replaced)
- Map light comes on when drivers door opens but is not responding to the switch that was tested and found to work when door is closed…
- Flashers will only work if the left or right turn signal is engaged first- (and then flasher switch pulled on) but when the stalk is returned to neutral the hazards will continue to flash but will not restart once the button is pushed in and then pulled back out…
- I only have a single blade yellow wire running to the pass side door jamb but can’t find a dome light switch to match- (just have a two blade in place for now that obviously doesn’t work right. (I bought a brand new drivers side switch with the two prongs and it seems to work as designed)
- Tested the map light switch and it works but does not control map light under any circumstances (door open/ closed) and the bulb has tested good.
