[WANTED] 1973 340 Exhaust Manifold Heat Stove
That shield does not fit exhaust manifold with casting number 3614368. I took it to the shop today and it doesn't fit. Do you know what manifold it was taken from?
Sorry to hear , dont really know which part # it came off ..dont know the one you need now.. send it back and I can refund your $$ really sorry again, thought it was one you were looking for!!!
I guess this is the correct piece. I also a pic of one on a car. Hard to believe it is thus hard to find. We are going to try to alter your piece to fit the manifold and use it until I find the correct piece.
WOW..yeah should be plentiful..ok will also check around for you..10-4
Yes it is, but that stove is different than yours. Look at the length of the bottom tab. It is also different in several other areas. Yes, I need both correct pieces. Notice where they connect.......
FYI....I am not unhappy with you! It's cool. I do want the right piece though. Your help is appreciated.
Thank you!! I really aim to please or make it right !!!
