1973 340 machine work done,longblock ready to assemble
superbyrd
henderson,ky
i have a 1973 model (cast crank) 340 engine. came from a 73 dart sport(casting date 9-27-72) block is bored .030 over (4.070), new freeze plugs,galley plugs,cam bearings. hot tanked,sonic checked,ready to assemble. has brand new cast 10.3 to 1 pistons,cylinders were power honed with torque plates to the pistons (pistons are true 10.3 to 1,2-valve reliefs, pistons sit .028 above the deck) pistons are already pressed on the rods.crankshaft was re-ground,polished .010/.010. comes with a set of correct,73 340 HP "587" J heads.these heads were on a different small block,they had fresh valve job,guides done,sonic checked about 10,*** miles ago,so they are ready to bolt on and go. comes with correct,73 cast crank specific harmonic balancer.and standard flexplate.engine comes with timing cover,valve covers,car oil pan. ready to reassemble. does not come with bearings,rings,timing chain,cam,lifters,ect. all work done by a professional shop. the machine shop bill,and the new pistons were more than my asking price so,don't try and low-ball me. price is $1000
PM me with questions and for phone number. thanks.
here are some pics: http://s207.photobucket.com/albums/bb102/superbyrd/73340LBpix2011/
