F fgrossi Well-Known Member Joined Oct 24, 2008 Messages 50 Reaction score 0 Rating - 0% 0 0 0 Aug 5, 2010 #1 Contact seller hi guys looking for 1973 340 timing cover,anyone got one? need the numbers to set timing as mine are missing. thanks
W wilbanks Well-Known Member Joined Jan 7, 2008 Messages 450 Reaction score 3 Rating - 100% 1 0 1 Aug 5, 2010 #2 Got one, shoot me a PM
C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 19,183 Reaction score 5,931 Location 92201 Rating - 100% 74 0 0 Aug 5, 2010 #3 If you aren't a numbers geek... That should be the same cover for any 69+ SB engine with a fuel pump provision. 318-340-360 all will work. That should expand your choices. You need the timing marks on the drivers side of the cover. I have one that will work for you.
