1973 440 short block. Fully machined 73 block, new cam bearings and freeze plugs. Cast crank, crack checked and ground .010 rods and mains. Reconditioned rods with new rod bolts. Silvolite .030 over cast pistons. Correct balancer. New rings, bearings, roller timing chain, HV oil pump. Small Crower Hydraulic cam. Correctly assembled, cam degreed and painted. 9.2 to 1 compression with 84 cc head. Perfect street motor. Located in NW Indiana. $1500 obo
