1973 dodge challenger,has been a drag car the last decade.no rust,older paint job,metal flake,has a few chips,dings,drivers door hinge sags when open(typical for e bodies)no motor/trans. roller right now been in storage the last few years.has stock front end with disc brakes and a new moser 60 rear with willwood discs and a spool,4: 10 gears. It has weld prostars and E.T. streets and front runners.professionaly built 8 pt. cage and frame work,tin work.needs a headliner,comes with cowl hood and 6 pack hood.set up for big block.everthing electrical works, Lots of parts too.valid tags,registered in Ct.,I would vaule it at $9500 to $13000 as a roller. Possible Trade for a running Mopar.Gene @ 1860-490-6253,Located in Tolland CT
