- Joined
- Mar 6, 2008
- Messages
- 1,477
- Reaction score
- 1,222
I put together a video of the test Dana67Dart recommends: Testing Mopar gauges on the bench
Nice, but as someone who has a real hard time diagnosing and repairing electrical problems, being able to see how the wires are connected would be helpful. Where is the red lead connected Mat.I put together a video of the test Dana67Dart recommends: Testing Mopar gauges on the bench
Did you watch the video in post 3?Nice, but as someone who has a real hard time diagnosing and repairing electrical problems, being to see how the wires are connected would be helpful. Where is the red lead connected Mat.
Thanks
Even that is not a constant year to year. I was just helping someone in another thread with a '63 (or maybe a '64) and the power feed is a black wire. Go figure its also one of the years with tougher to find manuals and diagrams.red lead goes to the pin the connects to 12 volt power.
The float is full of gas.
In this case, I meant the positive wire from the power supply shown in the video. Not anything in the wiring harness. Sorry if that wasn't clear from the post.Even that is not a constant year to year. I was just helping someone in another thread with a '63 (or maybe a '64) and the power feed is a black wire. Go figure its also one of the years with tougher to find manuals and diagrams.
I wonder if that's what the deal is with mine. Gets to E, takes 8 gallons to fill up. Then it reads 2/3 - 3/4 full.How much fuel is on your tank?
A float with a hold will fill with fuel and read empty.
Aftermarket senders need about 8 gallons in the tank to read other than empty.
OEM sender if functioning outside of the tank should read accurately
