1973 Duster Door car $37,500 obo
RPMMOTORSPORTS2
DUSTER 526CI
Rating - 0%
0   0   0
:clock:
73 Duster FOR SALE: Engine is a 526 cu in. wedge block, cast iron heads ported and polished 516's over size valves, Copper head gaskets, bottom end was built by Dynaflo in Nevada7 inch rods, SRP pistons, Stroker crank 4.375, 650 cam, solid roller, 1.7 roller rockers, full MSD ignition : Crank trigger, distributor, wires, coil Aluminum Valve covers, full headman headers turn out just behind front tires, 7AL-2 MSD ignition box with 3 step , 4 way cross over,. Powerglide transmission, with hughes electronic shift, Trans Brake, 8 inch 5000 torque converter, Full manufactured 9 in rear end From A.R.T. with Richmond 4.56 gears, large Strange spool, Strange axels 35 spline, Strange noduler housing, Ladder bars, QA-1 coil overs,twin 16 volt batteries in trunk. 3 gallon fuel cell in front of Aluminum radiator, belt driven fuel pump pushing Methanol to twinn Rons Flying Toilets with bird catcher scoop.. Frame is 2X3 front to rear Full cage front to rear certified to 8.50 NHRA New tires in front used in back. Disc brakes front and rear. Body is steel roof quarter panels, Fiberglass hood, doors, trunk lid, and front end is 1 piece. The car is brand new it has been on the track 1 time for test and tune it ran 55mph 1/8th mile 1/4 throttle just to make sure car was going to go straight, The next run was going to be a full throttle but never got to it. The car has been trailered or in a garage has been idled mostly for tuning. front and rear lights, chute, spoiler, I have over $50,000 in this car most everything is new and not cheap. Make me an offer All I can say is no, or I will think about it, or sold.
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0017.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0018.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0019.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0020.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0021.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0012.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0324.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0325.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0327.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0332.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0333.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0321.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0322.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0323.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0302.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0299.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0280.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0281.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0264.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0266.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0228.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0240.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0243.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0244.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0092.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0093.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0094.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0253.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0254.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0255.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0274.jpg
http://i418.photobucket.com/albums/pp262/RPMMOTORSPORTS2/HPIM0275.jpg
I hope these pictures answer some of your questions, if you have more questions e-mail me directly. I am on the computer more than the cell phone.
I hope this helps if you have any questions please don't hesitate to contact me.
Thank you
Roy L. Nelson
[email protected]
Now wouldn't that be FUN !!! Nice toy, is an understatement. Why did you never make the second run? Just curious.
Small Block
Fun!!!! wouldn't that Just pizz the neighbors off a wee bit when you torched it off.....cool car
Small Block
We were at a test and tune night, we were able to get the first run in at about 8:00 pm, and we had about 200 foreign cars running that night. I also forgot the battery charger, batteries were low, and I had to be at work at 0630 in the morning. So we loaded back up and went home.
