[SOLD] 1973 duster racecar bigblock
quartermilepass
New Jersey
Rating - 0%
0   0   0
1973 plymouth duster
440 build 727 83/4
Rack n pinion front end
Racecar car is very light
30 over Ross piston
Flat Top with valve pocket s 10.5 to 1 comp.
LY Chrysler rods cast
ARP bolts throughout
Steel crank good cam
Crower roller lifters and
Rockers
Heads are ported some
And matched to intake
Head studs ARP
Milodon oil pump and
Pan can hold 7 qts
727 trans good clutches, manual valve body ,trans break not Hooked up,turbo action parts , has a shield
8 3/4 rear 4.88 gears strangle axles and spool 31x13 tire 4 link
Fiberglass front flip ( hood is sperate )
Fiberglass doors and trunk
Doors have lexan windows
Whole floor is tin front to back
Will sell as a roller no motor no trans for 10k
Will also trade, other mopars/racecars
28+ loaded,mopar drivers, cummins,r.v.s
Send what u got no bikes
$14,750 new jersey
