[FOR SALE] 1973 LA timing cover, gaskets & related hardware.
Locomotion
Florida
1) OEM LA timing cover 1973 date code - $50.00 *****SALE PENDNG*****
2) Direct Connection cam bolt & washer for LA small block without fuel pump eccentric. $20.00
3) LA small block timing chain oil drip tab & 3 bolts - (One with oil hole.) - $25.00
4) Mopar OEM Oil slinger - $10.00
5) Mopar mechanical fuel pump chrome block-off plate w/12 pt. bolts. - $5.00
6) LA small block cam thrust plate. - $5.00
7) Mr. Gasket 9126G polished aluminum mechanical fuel pump block-off plate. - $10.00
8) Mopar oil filter adapter plate - 8 hole with 3/8" drive fitting. - $20.00
9) Victor Reinz 3536G LA head gaskets (3 pack) - $30.00 (For all 3)
10) ROL TS11201 Timing cover gasket set. - $10.00
11) Mr. Gasket 5935G Ultra Seal exhaust gaskets for small block A heads - $20.00
12) Mr. Gasket 5949G Ultra Seal exhaust gaskets for 318/360 Magnum - $20.00
13) TTI GA HG340 for Mopar small block heads - $15.00
14) Cloyes 9-135 St. replacement True Roller timing chain only - $40.00 ea. (3 available)
15) Cloyes 9-3103-5 (.005 short) True Roller Timing Chain Set$60.00/set
16) Cloyes 9-135-5 (.005 short) replacement True Roller timing chain only - $40.00
17) Fel-Pro OS 66566-3 360 LA oil pan gasket - cork/rubber - $7.00
18) Fel-Pro MS 90109 LA 318/30/360 intake gasket - $10.00 ea. (2 available)
19) Mopar 2951995 oil filter adapter - OEM cast iron - 3 23 1 casting date (needs gasket set or bolt/gasket set) w/bolt & original style oil filter fitting. - $40.00 *****SALE PENDNG*****
20) Mopar OEM oil filter adapter fitting - newer 3/8" drive style - $10.00
21) Mopar OEM oil filter adapter plate. - $10.00
All prices + shipping
from Florida 32117
Sorry, no PayPal
